During the simulation of WS2812, the lights on the 3D panel were on this time and then off again in the next simulation, which was irregular and unstable.
During compilation, an error occurs as shown in the figure.
Please check it out.
Acknowledgments!
WS2812 simulation and compilation errors
niedian
- Has thanked: 3 times
- Been thanked: 5 times
- 3.jpg (120.23 KiB) Viewed 3154 times
- 2.jpg (79.81 KiB) Viewed 3154 times
- 1.jpg (86.67 KiB) Viewed 3154 times
- Has thanked: 794 times
- Been thanked: 858 times
Re: WS2812 simulation and compilation errors
I have fixed the compile errors ,so hopefully your project will now compile.
If yoy want to test the updated component, browse to this location using file explorer , it's hidden by default so just paste the link into your address bar.
Place the attached component.
Can you let me know how you get on please.
The only thing I can see when when repeated stop/start simulation are the LEDs starting of bright then dimming to required brightness.
To me that looks normal.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- LED_WS2811.fcpx
- (18.09 KiB) Downloaded 200 times
Hello, thank you so much
Can compile normally now
It also runs normally on ESP32
However, occasional abnormalities still occur in 3D simulations
Thank you again, you're amazing
- Video_2025-10-13_163851.rar
- (3.58 MiB) Downloaded 186 times
- 9.jpg (82.36 KiB) Viewed 3117 times
- 8.jpg (688.76 KiB) Viewed 3117 times
