Is there a way to make a C block function Global ( can be called from all Macros ), other than putting it in the supplementary code ?
or can we just add a C file to the supplementary code?
If not, I think it should be possible to create a component that lets us add a C file
Global C-Code
Alan_37
- Has thanked: 57 times
- Been thanked: 28 times
- Has thanked: 292 times
- Been thanked: 458 times
Re: Global C-Code
You can create a normal macro in Flowcode that has the suitable parameters and return type for that function. In this macro add a single C-code icon and put the code of that function into that icon, matching the parameters of your C function with the parameters of the macro.
Or you can just use supplementary code. There was a discussion about this recently on this forum. A search for the word "supplementary" will bring that up:
https://www.flowcode.co.uk/forums/searc ... plementary
Re: Global C-Code
Hi Steve,
Thanks for your reply, that was exactly what I needed, to include a file and then use my favorite Editor .
The Absolute Path ended up being a bit complicated, but it worked
#include "Z:\\Mega_2\\STM ILLUMINATI\\FlowCode Base\\Suplimentary_Code\\UART3_DMA.c"
Thanks again
Thanks again
