Contents of an OR statement
Billduck1302
Has thanked: 2 times
Post by Billduck1302 »
I have an if statement "If Cell_1_Voltage_Float || Cell_2_Voltage_Float <= 3.0".
The intent was to terminate a process, if either cell, in a Nissan Leaf battery, fell below 3 volts, in a discharge capacity test.
Well, it did not work. Instead the following "If Cell_1_Voltage_Float <= 3.0 || Cell_2_Voltage_Float <= 3.0" did work. Thank you.
I am wondering how the processor interpreted the first statement.
Has thanked: 442 times
Been thanked: 661 times
Re: Contents of an OR statement
Leigh and Steve explain it well in this post https://www.flowcode.co.uk/forums/viewt ... 337#p21337
Hope this helps
Has thanked: 292 times
Been thanked: 458 times
It often helps to use brackets to describe your intent in these situations. Experienced programmers will often write code that doesn't use brackets and assumes anyone reading the code will understand the natural order of operators within C. But with the addition of a few brackets, it means even novice programmers should be able to understand what's intended.
I think your initial expression is trying to say "if either cell1 or cell2 is less than or equal to 3". We understand this in English, but the chip/computer will interpret this in stages. Just "if cell1" will be evaluated first, which will be true unless cell1 is zero. If it is true, then is will treat the whole expression as true and will not bother with the secondary "if cell2 <= 3".
If you put brackets around this like "if (cell1 || cell2) <= 3.0)" then this will also not work because "cell1 || cell2" will resolve first to either "true" or "false" (i.e. 1 or 0), and this will always be less than 3 and so the whole expression will always be true.
As you have found, the "correct" way to describe your intent in the code is to say "if (cell1 is less than 3) or (cell2 is less than 3)".
