Error Compiling STM32 (solved)
Alan_37
Has thanked: 55 times
Been thanked: 27 times
Flowcode v11 Error Compiling STM32 (solved)
Post by Alan_37 »
Hello ,
I have a file that was written in Flowcode 10. It compiles without any problems in V10, but in Flowcode 11, it gives this error.
I have tried adding "char FCLsz_TEMPSTR[100];" in a C block in the beginning, but it does not solve the problem .
C:\ProgramData\MatrixTSL\FlowcodeV11\CAL\STARM\STARM_CAL_String.c: In function 'FCI_EXPLODETOINTARRAY':
C:\ProgramData\MatrixTSL\FlowcodeV11\CAL\STARM\STARM_CAL_String.c:1032:66: error: 'FCLsz_TEMPSTR' undeclared (first use in this function)
FCL_DATAARRAY[FCR_RETVAL] = FCI_STRING_TO_INT(FCL_TEMPSTR, FCLsz_TEMPSTR);
C:\ProgramData\MatrixTSL\FlowcodeV11\CAL\STARM\STARM_CAL_String.c:1032:66: note: each undeclared identifier is reported only once for each function it appears in
Error(s) in build
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\ARM\batch\stm32comp.bat reported error code 0x1
Has thanked: 692 times
Been thanked: 763 times
Re: Error Compiling STM32
That issue has been fixed.
What you need to do is a full database component update.
Help > Library Updates...
Change Files in-use to Full database
Then you will need to reload your project.
The reason it worked with FC10 the component library was probably fully updated.
Alan_37
Post by Alan_37 »
Hi medelec35, thanks for your reply
Already did that right after installing today with no luck.
Yes, i saw the other post. I think the bug was fixed for PIC32BIT not for STM32
You're welcome.
Is this the post you are referring to?
Can you post your project .fcfx & .fcxlog.txt files
If you want to keep your project private, you could either pm it to me or strip it down, and attach it.
Make sure you still have the error
Alan_37
Post by Alan_37 »
Hi Martin,
There’s no need to upload any files — you just need to fix the file STARM_CAL_String.c.
Simply apply the same changes that were done in PIC32BIT_CAL_String.c, and that should solve the problem.
That said, if you still want me to upload the files, that’s not a problem. However, the code is a bit complex and requires including several supplementary files to compile properly.
Thanks in advance for your help — I really hope I can start using Flowcode 11 soon
407ZGT6_ILLUM.msg.txt
(3.29 KiB) Downloaded 116 times
The PIC32BIT_CAL_String.c was fixed.
That is why I added the link to show you that.
You have not attached the important .fcxlog.txt file, which may or may not give us a clue.
Can you attach that before we can continue.
Alan_37
Post by Alan_37 »
Yes here it is
407ZGT6_ILLUM.fcxlog.txt
(11.06 KiB) Downloaded 114 times
Alan_37
Post by Alan_37 »
Hi Martin,
Took a look at STARM_CAL_String.c and fixed the issue myself.
The error turned out to be a missing variable declaration, which needed to be replaced with the appropriate constant value representing the buffer size.
Now everything works and compiles OK, You can take a look and confirm everything is OK, and push the file for a global Update .
(10.79 KiB) Downloaded 125 times
STARM_CAL_String.c
(29.9 KiB) Downloaded 128 times
Re: Error Compiling STM32 (solved)
Hi Alan.
Many thanks for the STARM_CAL_String.c update.
Well done for resolving the issue.
As My project that uses advanced strings did not replicate the fault, would you mind attaching your .fcfx project please.
If you would like to keep it private then you can PM it to me.
Alan_37
Post by Alan_37 »
Hi Martin,
To replicate the fault, just open an STM32 Target and force flowcode to use STARM_CAL_String.c
Just put a C-Block with the following code and compile to Hex
void hexToString(unsigned char *hex, int len, char *out) {
for (int i = 0; i < len; i++) out = (char)hex;
out[len] = '\0';
You don't need to call the function.
