Modbus Communication Down
seokgi
Has thanked: 8 times
Been thanked: 9 times
Flowcode v11 Modbus Communication Down
Post by seokgi »
MCU : PIC24FJ512GA606
Communication : Modbus Slave Mode (RS-232)
This is an RS-232-based Modbus slave mode.
I'm using a Flash EEPROM component. The Flash EEPROM works fine. When I download a HEX file, communication works fine for a while, then stops. The digital output for monitoring works fine.
The same issue persists even after removing all other routines.
The device I compiled and installed previously on the same board (6/24/2025) works fine. After a reset, it works fine again, but then communication stops.
The same issue occurs with FC10 and FC11.
Please help.
Thank you.
seokgi
Re: Modbus Communication Down
Post by seokgi »
If I leave it on for a long time, it starts working again for a while and then crashes again, repeating the process.
Has thanked: 637 times
Been thanked: 847 times
Ok this sounds like a problem maybe to do with bytes getting dropped. The trouble is the CheckForIncoming has to be there to catch the bytes from the master and if you have anything that can cause delays then this can be disrupted.
I wonder if we can move the incoming data collection from the CheckForIncoming macro to an interrupt to improve the chances of keeping everything running.
If you like I can try and make this adjustment to the component and see if that gets us anywhere.
Do you have other interrupts in your program?
seokgi
Post by seokgi »
I'm using TMR5, RXINT2.
