i downloaded the toolchain for ESP32. However, if i try to install it i get an error message:
This program can only be installed on versions of Windows designed for the following processor architectures:
x64
I run Flowcode V9 on a Macbook under Parallels. Windows 10 in 32bit version without problems. I checked the Windows architecture i have and it says: x64, so i don`t understand why its not installing...?
Any help is appreciated!
Thanks a lot
maridd
ESP32 toolchain on x64 processor
marrid
- Has thanked: 292 times
- Been thanked: 458 times
Re: ESP32 toolchain on x64 processor
Unfortunately the ESP toolchain is not our product and is beyond our control to fix. Espressif's site says the following:
This might provide you with a solution, but we're limited in how we can help you with this.Currently only 64-bit versions of Windows are supported. 32-bit Windows can use the Legacy GNU Make Build System.
