App Developper active gradient change
Has thanked: 246 times
Been thanked: 258 times
Hi to All
I have various thermal sensors on a plate. I would like to change the gradient depending on the measured value in real time.
How can I do this?
I tried it but it didn't work active.
FC11_gradient_active_PC Project.fcpcd
(10.68 KiB) Downloaded 340 times
Has thanked: 311 times
Been thanked: 479 times
Re: App Developper active gradient change
The property value takes a string variable, but I think if this is a number then it may have to be a decimal number (i.e. instead of "FF" you should use "255").
Also, if you just want to change one side of the gradient, consider the "SetColor" function instead of "SetProperty" as that gives more control.
See attached.
FC11_gradient_ST.fcpcd
(11.06 KiB) Downloaded 314 times
Hi Steve
It's working nice.
Only the flame is red on the outside and blue on the inside.
It should be the other way around. But I'll try to fix that.
Here the result:
I suspect the string is not hex..
program for gradient
FC11_gradient_post2.fcpcd
(19.5 KiB) Downloaded 293 times
