Starm 042 not compile1
Has thanked: 792 times
Been thanked: 197 times
Flowcode v11 Starm 042 not compile1
Post by jgu1 »
Hi again!
Sorry, I can also not open and compile some of my Starm project in FC11. I att. a testprogram, pls
C:\ProgramData\MatrixTSL\FlowcodeV11\CAL\STARM\STARM_CAL_String.c: In function 'FCI_EXPLODETOINTARRAY':
C:\ProgramData\MatrixTSL\FlowcodeV11\CAL\STARM\STARM_CAL_String.c:1032:66: error: 'FCLsz_TEMPSTR' undeclared (first use in this function)
FCL_DATAARRAY[FCR_RETVAL] = FCI_STRING_TO_INT(FCL_TEMPSTR, FCLsz_TEMPSTR);
C:\ProgramData\MatrixTSL\FlowcodeV11\CAL\STARM\STARM_CAL_String.c:1032:66: note: each undeclared identifier is reported only once for each function it appears in
Error(s) in build
C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\ARM\batch\stm32comp.bat reported error code 0x1
Autoclose turned off
What do I wrong?
Jorgen
STM32F042 NUCLEOtest_48Mhz.fcfx
(7.08 KiB) Downloaded 104 times
STM32F042 NUCLEOtest_48Mhz.msg.txt
(3.34 KiB) Downloaded 97 times
Has thanked: 94 times
Been thanked: 288 times
Re: Starm 042 not compile1
Works OK for me.
Are you up to date with (full) library updates?
Flowcode v11 Re: Starm 042 not compile1
Post by jgu1 »
Hi LEigh!
just perform the full update, but still same message,, any idea?
It looks like the Matrix repo might be out of sync, my CAL file looks to be older.
See this post .. https://www.flowcode.co.uk/forums/viewt ... 794#p21794
Post by jgu1 »
Ok Leigh, is there no update for this STARM_CAL_String.c file? please
Matrix staff will no doubt sort it out.. probably next week :D
Meanwhile try the C file attached to Alan's post, to go into
Post by jgu1 »
Thank you Leigh.
Nice weekend :)
Has thanked: 575 times
Been thanked: 757 times
Hopefully resolved for you now.
Post by jgu1 »
Hi Ben!
Thank you. I test tomorrow :)
Jorgen
Post by jgu1 »
Ok now Ben, thank´s
Jorgen
