Kalman Filter Example
george_b
Has thanked: 13 times
Been thanked: 3 times
Flowcode v10 Kalman Filter Example
Post by george_b »
Hi all!
I would like to use the Kalman Filter compoment. I noticed that there is no examples for this component. However it looks to be simple implementation.
As an input to the KALMAN component i used the DSP Input Digital component and a float as a variable. Also a DSP Digital Output component connected to the output of the KALMAN component.
I am wondering if i need to keep the KALMAN component(Filter) in a continius loop ?
Thanks for your time to reply.
George
kalman filter.png (28.87 KiB) Viewed 1791 times
Has thanked: 246 times
Been thanked: 258 times
Re: Kalman Filter Example
Hi George
Here is an example of my filter. You should do this with every value.
george_b
Post by george_b »
Thank you for your time and your reply, I really appreciate it.
George
