Flowcode 9 crashing and freezing
Aspect_Carl
Post by Aspect_Carl »
I see things (Quality) didn't improve with matrix and flowcode since I bought V4 pro all those years ago :)
Anyway, thought I'd give V9 a go with arduino, on the 3rd go of starting a flow script, prior two attempts flowcode crashes and it has now frozen on the 3rd go.
Fault bucket , type 0
Event Name: BEX
Response: Not available
Cab Id: 0
Problem signature:
P1: FlowcodeV9.exe
P2: 9.0.0.23
P3: 5fca4815
P4: FlowcodeV9.exe
P5: 9.0.0.23
P6: 5fca4815
P7: 00d2ed4f
P8: c0000409
P9: 00000007
P10:
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_FlowcodeV9.exe_2183a0bff110ddf9d2c3c16d44d7c7983b61f05a_c7b7fca3_af599b7a-09c9-44ec-a68a-652a001826a9
Analysis symbol:
Rechecking for solution: 0
Report Id: 14da543a-286a-42d2-bb82-72e17aa15cce
Report Status: 4
one of the earlier crashes:
Faulting application name: FlowcodeV9.exe, version: 9.0.0.23, time stamp: 0x5fca4815
Faulting module name: FlowcodeV9.exe, version: 9.0.0.23, time stamp: 0x5fca4815
Exception code: 0xc0000409
Fault offset: 0x00d2ed4f
Faulting process ID: 0x560c
Faulting application start time: 0x01d7225c312cc6ee
Faulting application path: C:\Program Files (x86)\Flowcode v9\data\FlowcodeV9.exe
Faulting module path: C:\Program Files (x86)\Flowcode v9\data\FlowcodeV9.exe
Report ID: 14da543a-286a-42d2-bb82-72e17aa15cce
Faulting package full name:
Faulting package-relative application ID:
Has thanked: 231 times
Been thanked: 392 times
Re: Flowcode 9 crashing and freezing
That's surprising. We're not getting many reports of this kind of thing.
Can you please send me a project file and give me steps so I can try to replicate the issue. And is there anything particularly unusual about your setup (e.g. running in a virtual machine) that could be causing you to have problems?
szamy
Post by szamy »
Gábor Szeglet <Removed personal email address - Admin>
16:09 (15 perccel ezelőtt)
címzett: Liam
i wrote here, yesterday (but my post disappeared 😯. strange, i remember, i click to submit ):
viewtopic.php?f=5&t=348
it was (or similar):
"hi,
i have a FC9, purchased at 09/03/21 .
i used this program last time around end of 2021. today i tried to use again, but when i click to BUILD icon, i get an error message (below).
i tried with different PIC, and tried with empty project, same result. moreover, i cant close this message window, appear again and again (i cant save the project), and i need to shutdown the FC9 from task manager. before i used the FC9 today, i allowed a core upgrade...my FC9 worked before.
the error message:
"Flowcode has encountered a problem from which it is unable to recover. Please save your work and then close and re-start Flowcode"
i tried to delete/reinstall without core update, dosnt helped.
problem appaear with empty project too, immediately, when i click to BUILD.
thanks forward: Gabor
(my ID: 39218395)"
Has thanked: 665 times
Been thanked: 744 times
Hi Gábor.
That issue has happened in the past for users that have not updated to the latest build (v9.3.1.36)
To do that check you have select Global Settings.. > Applications tab > Check for core updates on launch ticked.
You will also need to be updated with the latest components after doing a core update.
You can do that via Library Updates after running FlowcodeLauncher.exe - Shortcut
If Flowocde still crashes then it could be a third-party application e.g. antivirus or firewall blocking access to Flowcode v9 exe.
szamy
Post by szamy »
Thank You!
now it works!
best regards: Gabor
Hi Gabor.
That's great!
Thank you for letting us know all is now working.
