App Developer Speed increase
Has thanked: 246 times
Been thanked: 258 times
The App Developer runs on my PC as if in slow motion. What is the reason for that? This setting?
Can I somehow increase the speed?
Has thanked: 311 times
Been thanked: 479 times
Re: App Developer Speed increase
Hi Stefan,
Are you able to send me a simple example project with the problem that I can test with?
Hi Steve
I tried to sample 12channel with 2kHz and save it on the SSD disk on my computer. The generated file AD0001.wav I can easy openthe file with audacity and its shows all the signals. The setup from the 12 DSP-Generator was different frequent and signal form (sinus square triangle)
The App is working nice but there is a speed problem. I turned of 11 from the 12 DSP generator and use just one. I added a on the end a samplecheck like samplecount/second and I have always strange results. I tried different interrupt time. I tested until 250Hz samplerate.
My computer is not really hard working while the app is running.
Thanks, Stefan.
Ben is more familiar with the DSP components and should be able to help with this. Unfortunately he is on holiday at the moment and so you might not get a reply for a few days. I will make him aware of this issue so he can try to help when he returns.
An update on this:
I have recently fixed an issue where App Developer was running at around half the speed a simulation runs in the main Flowcode exe. We should have a fix released in a v9.2 release, which should be out in July.
