Posts: 2153 http://meble-kuchenne.info.pl
Has thanked: 174 times
Been thanked: 994 times
Post
by mnfisher » Fri Jan 09, 2026 9:21 am
The timer component generates the following:
MX_UINT32 FCD_026e1_Timer1__GetCountMilliseconds()
//Local variable definitions
MX_UINT32 FCL_COUNT;
MX_FLOAT FCL_FVAR;
MX_UINT32 FCR_RETVAL;
#if (0)
//Code has been optimised out by the pre-processor
#else
FCL_COUNT = FCD_026e1_Timer1__GetRawCount();
FCL_FVAR = flt_mul(0.000000, flt_fromi(FCL_COUNT));
FCR_RETVAL = flt_toi(FCL_FVAR);
#endif
return (FCR_RETVAL);
The flt_mul by 0.00 - means the result is always going to be 0 - and seems to apply to all the GetCount macros.
Posts: 2153 Joined: Wed Dec 09, 2020 9:37 pm
Post
by mnfisher » Fri Jan 09, 2026 10:57 am
No - it's me = the default instruction rate is 0....
Post
by mnfisher » Fri Jan 09, 2026 11:38 am
There is, however something not quite right... Consider the attached - on an interrupt (on pin d2) - it toggles the LED on pin 13 - and outputs the number of 'ms' since the last (falling edge) interrupt.
I also have a scope attached to d2 - and a signal generator. The time displayed (with an input period of 8s) - not only vary wildly (from about 280ms to 172000ms - despite the reset timer..) - also the times are displayed every 1s (roughly) - so something odd going on - not only is the interrupt occurring at random intervals - but the times displayed bear no real relation to the actual time. Maybe 'noise' for the interrupt - but the time is wrong....
Results are 'better' using timer2 - and better again using timer0 - but still not great. I wonder if UART is using timer1?
pulse_328p.fcfx
(15.62 KiB) Downloaded 351 times
Post
by mnfisher » Fri Jan 09, 2026 12:12 pm
I added a second timer - and had timer 1 use Tmr0 and timer2 use Tmr2 - printing both values gives :
Tmr1 = 48 tmr2 = 383ms
With a 50ms pulse. Something wrong in the calculation for tmr2 - even allowing for the slight delay in getting the value?
pulse_328p.fcfx
(18.13 KiB) Downloaded 352 times
Post
by mnfisher » Fri Jan 09, 2026 12:16 pm
And adding timer1 into the mix:
Tmr1 = 46 tmr1 = 2028 tmr2 = 372ms
Tmr1 = 46 tmr1 = 2061 tmr2 = 372ms
Tmr1 = 46 tmr1 = 2094 tmr2 = 372ms
Tmr1 = 46 tmr1 = 274875840 tmr2 = 372ms
Tmr1 = 38 tmr1 = 274875872 tmr2 = 304ms
Tmr1 = 3 tmr1 = 274875872 tmr2 = 29ms
Tmr1 = 46 tmr1 = 274875936 tmr2 = 369ms
Tmr1 = 45 tmr1 = 274875968 tmr2 = 367ms
T
Posts: 2272 Joined: Mon Dec 07, 2020 10:06 am
Has thanked: 629 times
Been thanked: 836 times
Post
by BenR » Tue Jan 13, 2026 10:32 am
Thanks Martin,
I'll investigate and see if I can work out what's causing this.
