xpt2046 read wrong coordinates
simisv
Has thanked: 5 times
Been thanked: 5 times
Flowcode v10 xpt2046 read wrong coordinates
Post by simisv »
I'm trying for first time resistive touch xpt2046 on a ESP32 CYD module using Flowcode 10 . This module was tested using Arduino IDE and is 100% ok .
Display used is 320x240 ili9341 .
Using Flowcode : X axis value is always 0 , y axis value is 39 when there is not touched and 2 to 36 when touched from top(2) to bottom(36) .
I don't know how to move forward in to solving these issue .
Any help much appreciated .
Thank you
esp32_si_display_temp_dht22_forum.zip
(12.13 KiB) Downloaded 238 times
Has thanked: 647 times
Been thanked: 856 times
Re: xpt2046 read wrong coordinates
Have you tried changing the properties of the XPT2-46 component, e.g. the analogue mode from Differential to Single Ended?
You could also try changing the Channel to Software and see if that makes a difference.
simisv
Flowcode v10 Re: xpt2046 read wrong coordinates
Post by simisv »
Thank you Ben . You are right . Software SPI solved the problem and changing Analogue Mode to Single Ended . Unfortunately the IRQ pin stopped working so I have to use Pressure data . Pressure data shouldn't it be almost the same over the entire surface of display ?
Thank you for your help
Simion
esp32_si_display_temp_dht22_v2_forum.zip
(14.14 KiB) Downloaded 198 times
