ESP toolchain installation
RGV250
Has thanked: 46 times
Been thanked: 46 times
Flowcode v11 ESP toolchain installation
Post by RGV250 »
I know this toolchain can be a nightmare but personally I have never had any issues. I have a new Win11 PC that I have installed FC 10 & 11 on.
The ESP installation seemed to go as planned but when I tried to compile to target I had communication issues. After a bit of investigation the CP2102 driver was not installed. I might be wrong but I cannot recall needing to do this seperately in the past.
I know this is out of FC hands but wondered if it is a new issue it would be good to add this step to the installation guide. It was version 5.3a if that helps.
Bob
Has thanked: 616 times
Been thanked: 814 times
Re: ESP toolchain installation
Hi Bob,
It could potentially be a fake or less then legit version of the chip.
FTDI had a problem a while back where they actively blocked fake chips from auto installing using the drivers on Windows update. Could be a similar issue. Likely once a legit chip is detected and the official driver has been installed it will work for all the clones and copies too.
RGV250
Post by RGV250 »
Hi Ben,
The ESP32 I have has a Silicon labs CP2102 chip.
It might be that I have had to install it seperately on the other PC but just forgot about it?
Bob
Has thanked: 724 times
Been thanked: 783 times
Hi Bob.
I remember when I last reinstalled windows, I also had to install CP210X drivers, depending on thee ESP32 device used.
