The Nano program has the timed interval, the interrupt on Int0 and the PWM component (Timer0).
All works OK
After I add the modbus slave I have the error (during compiling):
: warning: #warning "PWM Channel Uses Resource Timer 0"
#warning "Period control register not available on target device, period will default to 255 + 1"
error: expected identifier or '(' before numeric constant
Looks like Nano does not have enough timers.
Is it the case?
Should I find a different way to communicate and move away from the Modbus?
FC11: variables conflict - solved
viktor_aust
- Has thanked: 18 times
- Been thanked: 5 times
viktor_aust
Re: FC11: Modbus conflict (Ard Nano)
Hi again
I checked the program with FC10; OK.
However cannot compile wihout errors with FC11
- FC11_Nano_25Jan26_Err.fcfx
- (42.03 KiB) Downloaded 219 times
- FC10_Nano_25Jan26_OK.fcfx
- (43.05 KiB) Downloaded 188 times
viktor_aust
- Has thanked: 616 times
- Been thanked: 814 times
Sorry for the delay, investigating for you now.
- Has thanked: 292 times
- Been thanked: 458 times
(I've just beat Ben to it I think)
I can see the problem and it will need a fix in some components and/or the actual Flowcode exe. But there is a workaround that should allow you to progress. The problem is that 4 of your global variables (text1, text3, text4 and text5) are clashing with some internal variables in a component. Just rename these (e.g. to "mytext1", etc) and it should compile ok again.
viktor_aust
viktor_aust
Re: FC11: variables conflict - solved
Thanks Ben and Steve.
Renaming the global variables solved the problem.
