I am looking at creating a rolling average macro, in a PLC I would create an array and populate it rolling over to zero and start again. I would then read the data back and if it crosses zero continue reading from the highest element.
As FC has a circular buffer I thought I would look into that, there are no examples so I have some questions.
Is there a limit to the size, if I am doing 15 mins I will need 900+ for 1 reading / second.
Put Data says it returns a zero if the buffer is full. If I set the storage type to "Store last x values" is this still correct as the buffer will always be full?
I think I will need to us GetIndexedValue but there is no information on which end of the buffer is the reference IE if I set the size to 1000 does it fill from 0 to 1000 or 1000 back to 0. If I then only want to read 900 values do I do 1000 to 100 step -1 or 0 to 900 step 1. This syntax might not be right for FC but I hope it makes sense.
Bob
Rolling average - circular buffer questions
RGV250
- Has thanked: 46 times
- Been thanked: 46 times
- Has thanked: 435 times
- Been thanked: 651 times
Re: Rolling average - circular buffer questions
Just a quick thought before bed.
Have you looked under both the Math and DSP>Math components as they may be able to assist?
- Has thanked: 159 times
- Been thanked: 943 times
Should be able to do what you want it to..
If you set to save the last '5' values (as an example - I know you will need more)
So it will always contain 5 values (after at least 5 have been read) - and adding new will overwrite the earliest data. However - get indexed value returns the value at the index of the array - so to give an example:
Buffer holds 1,2,3,4,5 (Why no demo with 900 items!)
PutData(6)
Buf = 6,2,3,4,5 (The data loops around - so now GetIndex (0) returns 6)
If you are averaging the last 900 (or 5) values - reading the values 0..899 (or 0..4 in my case) will still give the result you are after.
So 1,2,3,4,5 - Average(Sum(GetIndex[0..4]) = 15/5 = 3
6,2,3,4,5 - Average = 20 / 5 = 4
If you need the correct order of the values ( - getting faster 2,3,4,5,6) then an alternative is to store to an array - and once it is full shift everything along to the 'left' (strictly lower indexes) by 1
Array = 1,2,3,4,5 - Add new value (6)
for(i = 0; i < 4; i++) array = array[i + 1];
Array[4] = 6
Array = 2,3,4,5,6
This has the disadvantage that you are moving 900 (or more) values every time you add a value to the buffer (at least once it is full) - however this is a quick operation - and new reading every second - would be no issue.
As per Iain's reply - look at Math->running average - this may well do what you need!
Obviously your MCU will need sufficient memory to hold all the data - circular buffer uses an array (and extra head / tail pointers to keep track of the data)
PutData(6)
Array[4] = 6
Array = 2,3,4,5,6
Hi Martin,
For the last 5 mins would I do 0,1,2,3,4,5,6,7,8 Average(3(GetIndex[6..8]) or Average(3(GetIndex[0..2])
For the last 10 mins would I do 0,1,2,3,4,5,6,7,8 Average(6(GetIndex[3..8]) or Average(6(GetIndex[0..5])
Bob
Will do what I require and a very neat solution. I may allow to select the option for 5, 10, 15 mins so if I have 0-899 or 0-8So 1,2,3,4,5 - Average(Sum(GetIndex[0..4]) = 15/5 = 3
Bob
If using the circular buffer - then if you don't mind destroying the contents of the buffer - then it's possible - it returns the earliest samples first (so - if you want the last 10 - then discard until 10 (or 10 minutes worth) remain - then average)
If you need to keep all the values (user chooses last 5mins then - last 10mins) - then using an array and shifting might work better?
Hi Martin,
Thanks, I am surprised you say the circular buffer destroys the data, is this normal, in the Wiki GetindexedValue says it leaves the contents and pointers untouched. Or is in because in the example it is reading an array?
If that is the case I can loop through the values rather than reading in an array to do the same thing.
I cannot destroy the data as it is a rolling average that will constantly be being updated.
If it does indeed destroy the data I will stick with the way I know, a lot more long winded but I know it should work.
What I do is populate the array util it is full and then start again from zero overwriting the previous value, when I read the data (assuming 900 points) say from position 500 when I get to zero I read the next 400 from the end of the array. I think this is a lot more efficient than shifting the whole array every new entry.
Bob
Bob
It does 'destroy' the data if you use GetValue.
So if you need the last 5 values then GetIndexValue doesn't work - it does what you say - it writes to the end of the array and then starts again at the beginning.
It would be possible to create a circular buffer that has the behaviour you require (possibly by modifying the component code) - or use the shifted array as above.
- Has thanked: 607 times
- Been thanked: 803 times
The easiest way is to keep track of the total with an accumulator and to use the circular buffer to allow you to update the accumulator.
You initialise things by placing NumSamples of 0's in the circular buffer and assinging 0 to your accumulator. The size of your CB should be at least the number of samples you want to average plus 2.
Whenever you do a sample you first add it to the accumulator.
You then add your sample to the CB
You then get a value from the CB.
You then subtract the old sample from the accumulator
Now divide the accumulator by the number of samples in the buffer.
Be aware that the accumulator should be a big enough size so as to not overflow when samples are added, recommend an INT, Long or Float.
If the accumulator is an integer value (INT, Long) and NumSamples is a power of 2 (2,4,8,16, etc) then you can optimise a little by using a right shift instead of a divide.
There are components to do this for you, namely the modified moving average available from the Math section.
If you are getting the occasional very obviously incorrect value (e.g. because of noise or a comms error or an interrupt clash etc) then this will likely still effect your moving average, a small median filter placed before the moving average will see off this problem.
NumSamples = 5
CB::PutData(0)
CB::PutData(0)
CB::PutData(0)
CB::PutData(0)
CB::PutData(0)
Accumulator = 0Code: Select all
Accumulator = Accumulator + SampleCode: Select all
CB::PutData(Sample)Code: Select all
NthOldSample = CB::GetData()Code: Select all
Accumulator = Accumulator - NthOldSample Code: Select all
FilteredResult = Accumulator / NumSamplesIf the accumulator is an integer value (INT, Long) and NumSamples is a power of 2 (2,4,8,16, etc) then you can optimise a little by using a right shift instead of a divide.
FilteredResult = Accumulator >> NumSamplesP2If you are getting the occasional very obviously incorrect value (e.g. because of noise or a comms error or an interrupt clash etc) then this will likely still effect your moving average, a small median filter placed before the moving average will see off this problem.
Median::AddSample(RawSample)
Sample = Median::ReadMedian()Regards Ben Rowland - MatrixTSL
Hi Ben,
I may be wrong but that seems to be a rolling average from the start, I am looking for the last x mins. I also am looking at having a button where I can change from 5, 10 , 15 mins. I have had a think about how I think it will work so now I need to figure out how to simulate it. Something I am not good at with FC, not sure if it is easier with the Pro licence?
I did look at the Maths component as Chipfryer suggested in an early post but again was not sure.
Bob
Bob
Hello Bob,
Rather then rescanning back through the data you could either.
Have a differeny accumulator and individual circular buffers for each time period.
Or you could simplify and have a modified moving average filter for each time period.
Then simple display the result from the filter you wish to look at.
The only difference between each filter would be the number of samples it can hold.
