Blackpill awakening
max.tisc
Been thanked: 12 times
Flowcode v10 Blackpill awakening
Post by max.tisc »
is it possible to wake up the Blackpill cyclically from a sleep mode condition, for example every 5 minutes with the internal RTC? or any other suggestions?
thank's
Has thanked: 434 times
Been thanked: 651 times
Re: Blackpill awakening
I haven't used the Blackpill but from p434 (17.3.4) of the datasheet it documents wake ups from uS to 36 Hours.
max.tisc
Post by max.tisc »
but using FC10 components?
I would have thought so as it would most likely be a C-Block to set the registers. Page 434 gives details of how to use. Never having used the ST before I can only guess that you would use C-Blocks to set registers and to make it "Sleep".
max.tisc
Post by max.tisc »
yes but I wanted to know if FC10 had something ready to use
Has thanked: 102 times
Been thanked: 299 times
No, I don't think it does.
But after a super search, OK it was a bit of AI :roll: I found this ...
// Example to enter Sleep Mode
HAL_SuspendTick(); // Stop SysTick to prevent immediate wakeup
HAL_PWR_EnterSLEEPMode(PWR_MAINREGULATOR_ON, PWR_SLEEPENTRY_WFI);
HAL_ResumeTick();  // Resume SysTick after waking up
and had a bit of a play, so here's an example using the user LED and user key to put it in and out of sleep ...
STM32F411BP_SLEEP_DEMO.fcfx
(9.94 KiB) Downloaded 183 times
edit: oops, this was created in V11, should load OK but with a warning?
I've not had chance yet to look at the RTC interrupt.
As for waking up every 5 minutes, this should be possible with a timer interrupt.
Specifically with TIM2 and TIM5 that have 32 bit auto-reload counters.
However I'm struggling to discover how to change these from the 16 bit value limit, using parameters in the device FCD.
Matrix, is it possible to increase the Rollover Value to 32 bit?
max.tisc
Post by max.tisc »
ok thanks everyone for the suggestions, the TIMER1 and 5 issue is worth looking into in more detail for battery systems that require the greatest energy savings
