Display manager macro Colours property
Amagg
Flowcode v11 Display manager macro Colours property
Post by Amagg »
Could you please give me an example of how to fill out this Colours property present in several Display Manager macros ( like CreateObject ).
I have not been successful and I get Syntax error all the time.
BYTE Colours
Byte array containing FgColour RGB [0-2], Bg Colour RGB [3-5], Text Colour RGB [6-8]
Has thanked: 590 times
Been thanked: 778 times
Re: Display manager macro Colours property
If your using the display creator components on the scene then you don't have to manually call CreateObject / CreateWidget.
Some info here on this. https://www.flowcode.co.uk/wiki/index.p ... ay_Creator
If you still want to call those functions yourself then you can do so by providing a byte array.
Create a Byte variable with this name Colours[9].
Then in a calculation you can assign the colours.
//Foreground = Red
Colours[0] = 255
Colours[1] = 0
Colours[2] = 0
//Background = Green
Colours[3] = 0
Colours[4] = 255
Colours[5] = 0
//Text = Blue
Colours[6] = 0
Colours[7] = 0
Colours[8] = 255
Finally simply pass Colours as the parameter to the CreateObject function.
