Page webserver
max.tisc
Been thanked: 12 times
Flowcode v10 Page webserver
Post by max.tisc »
Hi, I'm playing with the Webserver component. I see that the pages are limited to 4. Can I increase them? Can I use another webserver icon to get more pages?
grazie
Has thanked: 312 times
Been thanked: 481 times
Re: Page webserver
I don't think there is a way of increasing this without editing the component (edit: there is :oops: - see Ben's answer!). An alternative is you could serve the pages manually instead of relying on static pages. It's more work, but would allow you to show any number of different pages.
Has thanked: 649 times
Been thanked: 856 times
Re: Page webserver
The easy way to allow for more files is to change from embedded pages to external using the HTML source property of the Webserver component and a FAT component. You can then put all your HTML source onto an SD card.
https://www.flowcode.co.uk/wiki/index.p ... etworking)
Steve's suggestion of serving pages up on the fly is also viable.
If you still want embedded only pages then how many would you need?
