Hi All, I have the micro -> PIC32MM0256GPM48
In the list not found, how are can i insert?
I make the project to this microcontroller, e i not want use mplab.
Thanks so much
PIC32MM0256GPM48
hiromiyureei
- Been thanked: 5 times
- Has thanked: 650 times
- Been thanked: 856 times
Re: PIC32MM0256GPM48
It looks like this device is currently not supported by the compiler in the Flowcode PIC32 toolchain. I can maybe have a look at adding this device into Flowcode but you will have to install your own version of the XC32 compiler to compile to this device.
