Flowcode v11.0.1.14
Locked
Has thanked: 300 times
Been thanked: 465 times
Flowcode v11 Flowcode v11.0.1.14
A new core update to Flowcode v11 is now available. This version is v11.0.1.14 and if you are running a version of Flowcode v11 prior to this latest release, the following notification will appear allowing it to be downloaded and installed:
Alternatively, this new version is available from the Flowcode download page, and instructions to update Flowcode can be found here: These are the main changes since the initial release (v11.0.0.8) from October 2025:
Bug fixes:
  • Fix to line thickness and font size when zooming 2d panel
  • Fixed Theme cookie for web-based views
  • Fixed crash when displaying submenus (e.g. from comp library right-click menu)
  • Fixed internal renaming of <GetHtmlElement> API call
  • Web Developer code gen fixes (buttons/switches when grouped; global comp vars)
  • Fixed a few undo/redo problems with macros/parameters
  • Fixed crashes when project has no <main> macro
  • Fixed crash when global option for c/h files is changed to false and this window already exists
  • Gauges within groups/components now capture the mouse properly
  • Mouse events are only passed to subobjects if they are under the mouse (or if they are captured gauges)
  • Switch primitive now prevents thumb being drawn if using images
  • Gauge primitives update their value property correctly when clicked
  • C-code in-situ edits prevented unless licence allows it
  • Property list APIs now ignore consecutive delimiters (e.g. to allow training commas at end of lines)
  • Bug fix when retrieving panel component list via API commands
  • Various other crashe fixes (refresh ping; connection points; interrupt sim)
Added:
  • New "Blueprint" functionality (see wiki for more details)
  • Project file now gets uploaded when a crash is uploaded
  • Added COM port autodetect
  • Added rescan button for detecting downstream boards on E-Blocks 3 h/w
  • Component search window toggles and combo gains focus when window first opens
  • Variables can be copied and pasted between macros and projects (via Project Explorer)
  • Improved code indentation when moving C code blocks
  • Improved various context menus
  • Bad FCD reporting now shows correct error location in the file
  • Command icons enabled only if appropriate macro type is visible
  • Online window default size increased
  • Added Set Icon Colour to macro and command icon lists context menu
  • Icon Colour for macro and command icon lists also optionally colours future icons of that type
  • Rescan E-Blocks now minimised FCD reading and uses dedicated <scannable> FCD entry
  • Added options to control the axes and gridlines for the <basechart> primitive
  • Added API collision detection on 2d panels: Get2dCentrePoint, GetFirstCompFromPoint, Get2dCompFromVector
  • Added inbuilt StringToIntEx$ function (has additional base parameter)
  • Added inbuilt abs() function
  • Improved detection of implicit STRING casting for calculations
  • Array initialisers perform simpler text-only check for constants when determining var/const usage
  • In-app browser links (e.g. in wiki and forum) can be opened in external browser via context menu
  • Float properties now support standard form (e.g. 1.23e-06)
  • Trailing '.0' is forced if showing a float property integer value
  • Better c/h toggle mode in code viewer
  • Added message details when loading a project
  • Mouse events are sent to all subcomponents (not just the top-most one)
  • Added optional Flowcode version and Software Assurance restrictions for Library Updates
  • History comment displayed in Library Update dialog
  • Obsolete local files are now removed from %PROGRAMDATA%
  • Added <Inactive Style> property to Switch, Gauge and NumericIndicator to control how they look when inactive
  • Library updates removed when running new version for the first time
  • Templates are sorted by displayed name (and not filename)
  • Starting a new project now causes a check for updated FCD/CAL
Locked
