ADS1115 An0 not simulate - Resolved
Has thanked: 839 times
Been thanked: 205 times
Flowcode v11 ADS1115 An0 not simulate - Resolved
Post by jgu1 »
Hi team!
I can not manage to get the An0 work in simulation mode in the ADS1115 component, have I forgot something, please? :roll:
Jorgen
ADS1115Test.fcfx
(9.1 KiB) Downloaded 247 times
Has thanked: 292 times
Been thanked: 458 times
Re: ADS1115 An0 not simulate
Thank you for reporting this. I can see the problem and will try to get a fix out soon.
The problem is that another subcomponent is blocking most of the left-most gauge. It doesn't completely cover the gauge and you should be able to click it near the top and it will work. This means that as a workaround, you should be able to click near the top of the component and drag the pointer to the required gauge setting.
Has thanked: 616 times
Been thanked: 814 times
Many thanks for reporting. This should be resolved for you now via the library updates.
Post by jgu1 »
Steve and Ben, thank you both, running perfect now ;)
Jorgen
