VL53L0X1 Showing only High Repeated Number
Matrixv8
Been thanked: 4 times
Post by Matrixv8 »
Hi everyone, I am working with the VL53L0X1 component. As per the attached program I am only getting the value 7903mm from the module. The component is set to long range. I tested other modules and I got the same result. I looked at the forum and no solution for my problem. I am using an Attiny84 chip. I tested the module with an Arduino Uno VL53L0X1 example sketch and the module works fine.
I would appreciate if someone could help please
Pierre
Station Sensor VL530L0X Attiny84.fcfx
(14.63 KiB) Downloaded 200 times
Has thanked: 633 times
Been thanked: 837 times
Re: VL53L0X1 Showing only High Repeated Number
Hello Pierre,
The ATTINY is running at 8MHz, half the speed of the Uno. Is it possible to try changing the crystal and boostig this to 16MHz to see if that makes a difference
Matrixv8
Post by Matrixv8 »
Thank you for your reply. Yes you are right, I reconfigured my program for the UNO and it worked but only on short range. I also boot loaded an Attiny85 at 16MHZ and it worked on short range not long, I do not know why.
Pierre
Hi Pierre,
Ok thanks for letting us know I'll see if I can replicate the long range issue here and see if I can get it fixed for you.
Matrixv8
Post by Matrixv8 »
Thank you,
Pierre
Matrixv8
Post by Matrixv8 »
Hi, I was woundering if there was an update on the VL530X1 long rage code for the flowcode component.
Pierre
