Problem with unsigned divide
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi All,
I am having an problem with a unsigned divide I am not sure what I am missing or doing wrong
Variable Raw is a unsigned int and factor is also an unsigned int value 32768 by dividing it to get the Resistance send from the MAX31865 SPI as per datasheet my result is always 0.0 ,Resistance is a float variable ,
when I just use a value of 32 for the factor then I get a result it is somehow connected to the 32768 number ,
How can I solve this or how can I use the type conversion component to do this
Divide by 32 give a correct result but using the factor of 32768 does not work what Am I doing wrong
Has thanked: 177 times
Been thanked: 1016 times
Re: Problem with unsigned divide
Post by mnfisher »
Hi Peter,
Currently your result is changed to float after the division..
Either need
fresult = n / 32.0
or fresult = float(n) / 32
Has thanked: 302 times
Been thanked: 469 times
Raw and Factor are both integers, and so the result of their division will also (initially) be an integer. This will be zero because Factor is high. Only then is it converted to a float.
Instead, you should do the divide using at least one float number.
One way to do this is to first set Resistance = Raw. Then perform Resistance = Resistance / Factor.
(edit: Martin beat me to it!)
p.erasmus
Post by p.erasmus »
Hi Martin / Steve
Thanks so much you pulled me out of this loop :D
I almost have no hair left
Many thanks again it is working spot on now :D
