Parity bit
viktor_aust
Has thanked: 18 times
Been thanked: 5 times
Parity bit
Post by viktor_aust »
Tuss4470 IC uses SPI to communicate with the Master.
Data format: (Reading the register)
msb = 1 r/w bit + 6 regi-addr bits + parity bit
lsb = 0x00
Odd parity bit should be calculated.
The open source project uses the next:
byte tuss4470Parity(byte* spi16Val)
return parity16(BitShiftCombine(spi16Val[0], spi16Val[1]));
unsigned int BitShiftCombine(unsigned char x_high, unsigned char x_low) {
return (x_high << 8) | x_low; // Combine high and low bytes
byte parity16(unsigned int val) {
byte ones = 0;
for (uint8_t i = 0; i < 16; i++) {
if ((val >> i) & 1) {
ones++;
return (ones + 1) % 2; // Odd parity calculation
Is it possible to calculate the parity bit for msb only (as the lsb = 0x00)?
Is it better to calculate the parity bit for integer (msb << 8) + lsb ?
viktor_aust
Re: Parity bit
Example
Data (16-bit): 1010 0101 1100 0011
Count of 1s: 8 (even)
Odd Parity Bit: 1
Resulting frame (with parity): 1010 0101 1100 0011 + 1
Has thanked: 163 times
Been thanked: 960 times
Re: Parity bit
Post by mnfisher »
I would probably count the bits in both MSB and LSB. If a byte (LSB or MSB) is 0 - it won't affect the parity value - but if there is an error in transmission then it might not be 0 - and will affect the final result (if you use (MSB << 8) + LSB)
Alternatively - if LSB must be 0 - ignore it - and use result = (MSB << 8)
I think option '1' would be more likely to detect errors (due to noise) on the line?
viktor_aust
Re: Parity bit
Thanks Martin
However I do something wrong.
On the attached example the
byte = 10011100 (4 ones)
however the parity check = 5
As I use the byte only, this byte has: 1bit (r/w)+ 6 bits (regi addr) + 1bit (parity).
Should I remove the parity bit during the calculations?
FC11_Nano_parity_1.fcfx
(18.88 KiB) Downloaded 77 times
Re: Parity bit
Post by mnfisher »
Rather than using an if .... statement to calculate the parity bit (and brackets might change the result here if (.x == 1) || (.x == 3) etc (you have if x==1 && x= 3 && x=5... which can't ever be true)
Depending on whether you need odd or even parity:
Use .parity = .x & 1 Returns .parity = 1 if an odd number of bits set
Or if it needs to be 1 for an even number of bits:
.parity = (.x + 1) & 1
Where .x is the number of bits set.
