Frustration with Flowcode inconsistency
RGV250
Has thanked: 46 times
Been thanked: 48 times
Post by RGV250 »
Is it just me but I get frustrated when I find and example and after making it work how I like I then find the component does not work the same in the format I am using.
This instance I am looking at is the radio button. There was no example in the web app section but I found one in the app developer section. I modified it and was happy it worked how I wanted. I then went to add it to the web app project I am working on and found it is totally different.
It is really frustrating to find things that should (in my opinion) work the same but are totally different.
In the app developer version the radio button has a property to select how many buttons, you can set the button texts etc all in the same component.
In the web app it is one button that you then have to group with others but no example how to do it.
Just why they are not the same is beyond me as they do exactly the same thing and to make them different but with no example is really is frustrating.
Making them different surely actually makes more work, if they were consistent there would not be as much need to make individual examples?
Bob
RGV250
Re: Frustration with Flowcode inconsistency
Post by RGV250 »
I think this follows on from my post regarding the 7 segment display that does not have a "show segments" component in web app where app developer does.
Bob
Has thanked: 312 times
Been thanked: 481 times
Although Embedded and PC Developer share many similarities and often the components used in one are the same as the other.
Web Developer is fundamentally different. It is based on JavaScript rather than C and the simulation is inherently different. Programming concepts for a browser-based environment are also different and so you will need to approach programming in a different, event-driven way.
These differences often mean that components in Web Developer need to behave differently.
Essentially, you will not be able to use Embedded or PC Developer examples as a basis for Web Developer applications.
That said, the common environment of Flowcode should help when creating Web Developer applications.
RGV250
Post by RGV250 »
Hi Steve,
Thanks for the explanation but surely that just makes it even more important to have examples for where there are differences.
Bob
We have plans to improve Web Developer and having more help and examples on the wiki is part of that.
If you ever can't find info in the wiki (because even when it is there, it is sometimes easy to miss), then please post specific questions on these forums.
We try to be responsive and are happy to help. Plus our other users (and our knowledgeable VCs) are often able to respond with help before we are.
grout1
Post by grout1 »
Hi Steve
I really like the concept of flowcode, I have succeeded in writing and flashing esp32 devices. I am a hobbyist and as such have no real knowledge of programming in C, hence using Flowcode. I understand there are issues with compiling for esp c devices. Most of the suggestions seem to describe complex adjustments in the windows environments etc. I can use the Arduino ide for these devices without problems. I purchased the esp licence so as to use the C6 devices, it seems they are not working for me. Can I at least use the C output from Flowcode to compile to bin? Using esprissive IDE.
Thanks. grout1. email dave.grout@xtra.co.nz
Has thanked: 650 times
Been thanked: 856 times
Yes this should work ok.
