Flowcode v11.0.2.17
Locked
Has thanked: 300 times
Been thanked: 465 times
Flowcode v11 Flowcode v11.0.2.17
A new core update to Flowcode v11 is now available. This version is v11.0.2.17 and if you are running a version of Flowcode v11 prior to this latest release, the following notification will appear allowing it to be downloaded and installed:
latest core update.png (14.18 KiB) Viewed 9030 times
Alternatively, this new version is available from the Flowcode download page, and instructions to update Flowcode can be found here: These are the main changes since the previous release (v11.0.1.14) from March 2026:
Bug fixes:
  • Invisible subobjects do not get mouse events
  • Fixed wiki xml generation so it ignores hidden components
  • Fixed bug where Flowcode becomes unresponsive when closing last-but-one macro tab
  • <SplitString> now deals with consecutive delimiters (returns nullstring instead of ignoring)
  • Fixed expression beautifier so it deals with multidimensional arrays
  • Fixed a few GDI resource leaks
  • Dragging icons to another flowchart (or ctrl-drag) does not trash the clipboard
  • Minor visual fix when dragging component macro on that has no parameters
  • Fixed bug where swapping language caused problem with recent chips
  • Trapped a crash when setting an illegal array initialiser
  • In ICD mode, pausing at a breakpoint now refreshes vars in Project Explorer
  • Switch icon now simulates properly
  • Fixed a stack bug when simulating the postinc, etc, maths functions
  • Fixed a stack bug when simulating the State command icon
  • Fixed indentation of code (e.g. for customised code, drag/drop, etc)
  • In-situ editing of code no longer includes automatic indentation
  • Minor fix to insertion point when dragging to move commands in text-based views
  • Fixed varname when asking to create an unknown local variable
  • Fixed display of config dropdowns for high DPI displays
  • Fixed Property page header for high DPI displays
  • Fixed text entry glitch for high DPI displays
  • Fixed issues when converting to curved transition icon and deleting nodes
  • Interrupt options now default to first entry if missing in project file
Added:
  • Warns when exporting a component to %PROGRAMDATA%
  • Improved error message when missing a local var
  • API calls now allow implicit casting from float to string
  • Added 'break' and 'continue' as command icons
  • Added 'return' as a command icon (for premature return from macro)
  • Added a separate Label dialog
  • Renamed Connection Point commands as 'Label' and 'Jump'
  • Added <Expand::ComponentInfo> API to retrieve component info
  • Added loose typecasting for WebDeveloper projects (e.g. myStr = myInt is legal)
  • Search results list now has the searched-for term as a heading
  • Copying icons in code and pseudocode views also copies the selection as text
  • Added direct string comparisons (>, >=, <, <=)
  • Breakpoints and bookmarks can now be toggled when debugger is unpaused
  • Web Developer does not allow debugging until project is saved
  • Decision and Switch commands can now have breakpoints and bookmarks at end icon
  • End icon bookmarks (Loop, Decision, Switch) stored in saved file
  • Checkbox hover colour improved so it shows when ticked
  • Improved tooltips for chip config entries
Locked
