convert hex to integer { Solved}
steve001
Has thanked: 81 times
Been thanked: 30 times
Post by steve001 »
Evening all,
is there a command / macro to convert hex to integer in v9 ?
Has thanked: 234 times
Been thanked: 252 times
Re: convert hex to integer
Hi Steve
I'm not sure if you ask this.
your_variable = 0x4C
steve001
Post by steve001 »
Hi Stefan
I want to convert a returned hex value to a number
Is there a command, macro in V9 ?
Hi Steve
You mean you receive 2 ascii char like 4C and convert it in an integer like 76?
steve001
Post by steve001 »
yes that's what i want to do
steve001
Re: convert hex to integer { Solved }
Post by steve001 »
Was getting confused - old age setting in
i was looking at the debugger console following my results (didn't see the box ticked show integers as hex until after)
and also putting a 7 seg display on the 2D panel confirmed everything is correct.
I wont say how long i have wasted trying to sort that out :mrgreen:
Capture - Copy.JPG (62.81 KiB) Viewed 5546 times
