Bitfields in data
Has thanked: 165 times
Been thanked: 967 times
Bitfields in data
Post by mnfisher »
Currently I need to use bitfields in some code.
On a PIC I can do REGISTERbits.FIELD = value for register values. I wanted a simple way to do this for variables.
I could define two constants field_start, field_width
.mask = pow(2,field_width) - 1
.value = .value & .mask // Check the value will fit in the field
.mask = .mask << .field_start
.value = .value << field_start
.var = (.var & (~.mask)) | .value
An idea (which came to me as I drove home) to use just one constant....
Here the constant defines the field width and start
e.g. 0b00111100 would define a 4 bit field at position 2
The attached demonstrates this: It will be slower - it has to 'calculate' the shift needed by finding the start of the bitfield (on AVR and PIC this isn't too bad compared to .val = .val << .shift but other processors handle the multiple shifts in the same time as 1) Here I use 16 bit values (which is what I needed - but it could be modified for 8 or 32 bits.)
SetBitField modifies 'data' (it would probably be more correct to return the new value!)
Just added a GetBitfield too :-)
Modern processors (x86 etc) have an instruction that does this (and it allows masks such as 0b10101010)
An alternative:
The constant holds the field start and width - for example as 8 bits each in a 16 bit varIable.
Any thoughts / comments / ideas?
bitfield.fcfx
(12.68 KiB) Downloaded 56 times
Re: Bitfields in data
Post by mnfisher »
And I went with 4 bits (nibbles) each for width and position.
Make every byte count :-)
Has thanked: 296 times
Been thanked: 459 times
Thanks for sharing, Martin. That's a useful technique, especially when ram is tight.
I wonder if this can be implemented within a component or in Flowcode itself.
Post by mnfisher »
I did a quick component - assuming unused macros are optimised away.
This supports SetBitfield8, 16 and 32 (on an 8 bit MCU 16 and 32 bit shifts are rather slower)
GetBitfield8,16 and 32
SetField4bit and GetField4bit - set or retrieve a field using a byte where upper nibble is position and lower nibble is width of the field (only 16 bit here - but 8 bit could be supported (32 bit would need a word descriptor))
SetBit8, 16, 32 - sets a bit in a byte, word or long
Note that the Set 'field' macros modify the value passed (which must be a lvalue not a constant) - rather than returning a value. SetBit returns a value - this isn't consistent - and suggestions as to which is preferred? (Returning a value is probably better?)
Could add GetBit macros.
SetField macros can also be used to write / read single bits (but slower)
All should work in simulation too - I've only tested the 16bit variants if any one would to have a play and try some more values?
bitfield.fcfx
(27.04 KiB) Downloaded 8 times
Bitfield.fcpx
(2.3 KiB) Downloaded 8 times
