Power (pow) returns incorrect result
Has thanked: 165 times
Been thanked: 967 times
Post by mnfisher »
Just spent a while chasing a bug in my code - but it turns out 'pow' returns an incorrect value.
It actually returns the result - 1 (except for pow(2, 0) and pow(2, 1))
The attached demonstrates this behaviour (on an Arduino - other devices may differ?):
2**0 = 1
2**1 = 2
2**2 = 3
2**3 = 7
2**4 = 15
2**5 = 31
2**6 = 63
2**7 = 127
2**8 = 255 // The example in the WIKI should = 256!
pow_test.fcfx
(10.18 KiB) Downloaded 27 times
Re: Power (pow) returns incorrect result
Post by mnfisher »
It might be because it uses floating point...
pow(2, flt_fromi(FCL_I));
- not sure why it doesn't also do flt_fromi(2)?
However - it shouldn't make it so wrong ?
Wrote my own integer
Has thanked: 296 times
Been thanked: 459 times
Thanks, Martin.
I've just checked and confirmed this. But on an 8-bit PIC it's fine.
If I strip out the flt_* functions in C code, then there are some oddities:
FCV_F = pow(2, 4);   //this produces 16.00000
//but...
FCV_I = 4;
FCV_F = pow(2, FCV_I);   //this produces 15.999999
FCV_I = pow(2, FCV_I);   //this produces 15
(FCV_F is a float and FCV_I is an int).
So there is a truncation issue.
Perhaps the "pow" function in the Arduino is using some algorithm that makes the power calculation quicker, but introduces this truncation issue.
We'll continue to investigate.
Post by mnfisher »
This might give a solution:
#include <math.h>
#include <stdio.h>
int main()
    int a, b;
    // Using typecasting for
    // integer result
    a = (int)(pow(5, 2) + 1e-9);
    b = round(pow(5,2));
    printf("%d \n%d", a, b);
    return 0;
Which looks to give the correct result on both cases (from stackoverflow)
More on this. It's not a bug as such. It's the way the pow() function works in the C code for Arduino/AVR.
The pow() function returns a float. And if a float is casted to an int then this is a truncation rather than a rounding. So 15.999999 becomes 15 and not 16.
So in your code it's probably wise to use the round() function if you are definitely expecting an integer rather than relying on C casting.
myInt = round( pow(2, x) )
