Hi all
im trying to switch between 4 branches on a switch icon, i want to be able to select at random then by storing the position either 1,2,3 or 4 then to use the stored number in this case the variable "store" to proceed to the corresponding data on the following four branches SWITCH ARRAY "SELECT" disabled so if branch 1 selected once chosen by switch "GO" its isolated until the rest of the program is executed so in other words if any other selection pressed the selected led stays on regardless if another switch is pressed any help would be greatly appreciated
cheers bob
SWITCH WOES
siliconchip
- Has thanked: 21 times
- Been thanked: 1 time
- Has thanked: 465 times
- Been thanked: 696 times
Re: SWITCH WOES
Not too sure I understand what you want. Perhaps some punctuation would help <s>
Your chart simply loops and depending on button pressed illuminates the corresponding LED, keeping it illuminated until another button is pressed. What should it do?
siliconchip
Re: SWITCH WOES
Hi the leds are just purely to show what channel you select once selected the single switch then allows to come out the loop to do the rest of the program thats fine but when it comes out of this loop if you pressed any buttons to do with the leds they still change id like them to stay on the channel picked instead of still being able to be changed
Cheers bob
Cheers bob
Re: SWITCH WOES
So if I understand correctly:-
1) It loops until a button is pressed.
2) It illuminates an LED to illustrate which button / channel.
3) Keeps looping until "Go" is pressed.
4) Whilst waiting for "Go" to be pressed it should ignore all other button presses.
5) Once "Go" has been pressed it "does something".
6) It then presumably starts all over again?
Is the above along the right lines?
siliconchip
Re: SWITCH WOES
Its after go is pressed it should ignore all other button presses and stay on the chanel selected
Cheers bob
Cheers bob
Re: SWITCH WOES
One way is to :-
In your switch calculations include setting a Flag (e.g. Flag = 1 or such like) if a button is pressed
Before your switch component have a decision, if Flag = 0, then put your Switch component in the Yes branch
The chart will loop until you press a button, then as you will set your Flag it will no longer branch to your switch component at all.
Later, perhaps at the end of your Go branches you could reset Flag to 0 re-enabling the switch
There are other ways but this should help.
One way is to :-
