Hi I have been using a PIC18F87J50 with FC8 for some time and the other day it stopped opening, tried reinstalling which did not work.
So I installed a trial copy of FC9 and it will now open but will not compile to hex.
See bellow the following message from the compiler and the attached source code.
Target folder: E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working
Source name: E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working\LC02 Firmware - ULP V2.03 - 210412.fcfx
Title:
Description:
Device: PIC.18F.18F87J50
Generated by: Flowcode v9.1.0.27
Date: Monday, April 12, 2021 11:14:29
Users: 1
Registered to: jonathanm (jonathanm)
Licence key: Ladder
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Using <PICkit2 PK2CMD External Power> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\" 18F87J50 "E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working\" "LC02 Firmware - ULP V2.03 - 210412"
E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D79589982F2C26BF78BFC32C650CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE1BF2A9420263CDAEEC22F549213B2E20A6A0704CBC762DED
E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working>REM REVISION: 1.0
E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working>REM DATE: 29\03\2021
E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
E:\_TEFTRONIX\Tefol\Control Systems (Cards)\LC02\Flowcode 8\LC02 Firmware\Working>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8.exe" --chip=18F87J50 "LC02 Firmware - ULP V2.03 - 210412.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\pic\bin\picc18 --chip=18F87J50 LC02 Firmware - ULP V2.03 - 210412.c --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
LC02 Firmware - ULP V2.03 - 210412.c:
34387: #warning "This interrupt has previously been enabled, so the macro <Main_Int> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <Main_Int> may never get called." (warning)
34400: #warning "This interrupt has previously been enabled, so the macro <Main_Int> may never get called."
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC\PIC_CAL_ADC.c: FC_CAL_ADC_Enable_1()
3112: old_tris = *tris_reg;
^ (192) undefined identifier "old_tris"
^ (192) undefined identifier "tris_reg"
^ (981) pointer required
3113: *tris_reg = old_tris | tris_mask;
^ (192) undefined identifier "tris_mask"
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
PIC18F87J50 Not compiling in Flowcode 9 was working in FC8
jonathanm
- Has thanked: 2 times
- LC02 Firmware - ULP V2.03 - 210412.fcfx
- (1.4 MiB) Downloaded 395 times
- (view online)
- Has thanked: 794 times
- Been thanked: 853 times
Re: PIC18F87J50 Not compiling in Flowcode 9 was working in FC8
Hi, jonathanm,
I have created a temporary fix.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
Hopefully you will be able to recompile after reloading flowchart.
- PIC_CAL_ADC.c
- (126.9 KiB) Downloaded 428 times
