ECIO40P16 and dsPIC33EP256MU806 chip
kennethnilsen69
Been thanked: 2 times
Post by kennethnilsen69 »
I have make my own pcb with the same chip as in ECIO40P16 and there are a few things I do not understand
ECIO40P16 has an external crystal at 8MHz but runs at 140MHz. how is this possible?
Mine only works properly if I choose 8MHz but as you know, it is much slower than 140MHz. so what is it I have not understood here?
I also can't use USB to upload the Hex file. I have to use PICkit4. any tips on how I can do this? I have uploaded the same bootloader that must be used on ECIO40P16 for the USB upload to work.
If I erase the ECIO chip, it stops working with USB. and when I upload the bootloader the USB works again. so I know the bootloader is working properly.
But on my pcb it will not work. is unsure if this has anything to do with the crystal. any ideas?
Schematic.pdf
(113.69 KiB) Downloaded 377 times
