ESP32 MODBUS ASCII
pedrazzi
Has thanked: 3 times
Been thanked: 2 times
ESP32 MODBUS ASCII
Post by pedrazzi »
Hi, I am trying to make an ascii MODBUS with ESP32 wroom 32, but the compiler returns this error:
../main/esp-project.c: In function 'FCD_04c01_ModbusSlave1__SendAndCalcCRC16':
../main/esp-project.c:3226:9: error: 'FCR_RETVAL' may be used uninitialized in this function [-Werror = maybe-uninitialized]
Use: Reads the state of a single digital input.
Thanks in advance
test_MB_ASCII.fcfx
(9.96 KiB) Downloaded 649 times
Tecnoservice
Has thanked: 616 times
Been thanked: 814 times
Re: ESP32 MODBUS ASCII
Many thanks for letting us know. I have now pushed out an update to the update system that should solve the problem for you.
pedrazzi
Post by pedrazzi »
perfect! Thanks for the help..
I tested the serial (OK) then I put the ascii modbus program back, but this doesn't work ..
test_MB_ASCII.fcfx
(10.21 KiB) Downloaded 718 times
Tecnoservice
Has thanked: 103 times
Been thanked: 302 times
If you need 19200 baud, could you try setting this in the UART properties and remove the ChangeBaud(4)
Could you try that please?
pedrazzi
Post by pedrazzi »
the request is 9600 N 8 1, I put the setting at the beginning to be sure ..
Tecnoservice
pedrazzi
Post by pedrazzi »
I tried to remove the setting, but the result is always the same. the strange thing is that it doesn't even respond error ...
(this is the message: :010200010010ED.. 3a 30 31 30 32 30 30 30 31 30 30 31 30 45 44 0d 0a )
Tecnoservice
Could you check "Library Updates" "Full database"
pedrazzi
Post by pedrazzi »
actually it was not fully updated, I did the full update and restarted, but the problem is not solved :(
Tecnoservice
pedrazzi
Post by pedrazzi »
Hello, I also tried with another microprocessor (32U4 / Arduino Leonardo), but the result is the same, I'm afraid I'm making something trivial wrong ..
Thanks in advance
Tecnoservice
Can you explain a bit more about your setup, what you have connected and what you are trying to do?
The Flowcode Modbus Slave component is to be used for creating Modbus Slave devices.
If you are creating hardware to connect to an existing Modbus (slave) device, then you need to use the Flowcode Modbus Master component.
There are examples on the Flowcode Wiki, such as this one
https://www.flowcode.co.uk/wiki/index.p ... s:_System)
