Convert a character to its numerical value
alanwms
- Has thanked: 26 times
- Been thanked: 8 times
I notice that "stringtoint" does not allow operation of alpha chars. Only numeric chars. Do we have a method of doing that?
Re: Convert a character to its numerical value
Sure - I would like to stringtoint$("A") to have an outcome of 41 (I think that's the equate).
Currently I am achieving this with the function compare with "". That seems to give me an equivalency.
Wouldn't it be great to use stringtoint$ to get the equivalent decimal?
- Has thanked: 163 times
- Been thanked: 960 times
If you want the ASCII value 'A' = 65 = 0x41
So for a string : in a calculation block
Will get the value of the first character of the string
Or if you just want the value of a character
note the single quote ' instead of double quote "
You can use a character constant instead of a constant to make your code more readable to check if c is a digit for example
So for a string :
value = str[0]Will get the value of the first character of the string
value = 'A'You can use a character constant instead of a constant to make your code more readable
If c >= '0' and c <= '9'Martin
