After updating to v9.0.0.23, the compiler does not work
jirikadlcak
Post by jirikadlcak »
I have been a FlowCode user since version 4, license professional. The latest installed version is v9. As recommended, I updated to Flowcode v9.0.0.23. (The previous version of Flowcode 9 was fully functional). Unfortunately, since this installation, I cannot compile to the specified processor type dsPIC33EP256MU806. Compilation on BL0032, with the same processor, proceeds normally. The compilation ends with the attached message.
Where did I make a mistake in the settings, or how to proceed to achieve the functionality of the program?
Thank you for the advice.
-j-
Compiler report:
Target folder: C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021
Source name: C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021\I2C_v4_1_pracovni_08042020.fcfx
Title:
Description:
Device: PIC16.33E.33EP256MU806
Generated by: Flowcode v9.0.0.23
Date: Monday, April 12, 2021 10:16:02
Users: 1
Registered to: kadlcak (34536401)
Licence key: MXYUWW
https://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode v9\data\DefaultData\FlowcodeV9\FCD\PIC16\batchfiles\pic16_C30_comp.bat "C:\Program Files (x86)\Flowcode\Compilers\pic16\\" "I2C_v4_1_pracovni_08042020" "C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021\" "33EP256MU806"
C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program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
C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021>REM REVISION: 1.0
C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021>REM GUID: 7821ABE5-9E21-4744-81B7-3FF600B75DB7
C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021>REM DATE: 29\03\2021
C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021>REM DIR: FCD\PIC16\batchfiles\pic16_C30_comp.bat
C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\Program Files (x86)\Flowcode\Compilers\pic16\\support\h" -I"C:\Program Files (x86)\Flowcode\Compilers\pic16\\" -std=gnu99 "I2C_v4_1_pracovni_08042020".c -o "I2C_v4_1_pracovni_08042020".o
coff-gcc.exe: no input files
Error returned from [xc16-gcc.exe]
C:\Program Files (x86)\Flowcode v9\data\DefaultData\FlowcodeV9\FCD\PIC16\batchfiles\pic16_C30_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Error_massage.docx
(13.3 KiB) Downloaded 709 times
Has thanked: 258 times
Been thanked: 414 times
Re: After updating to v9.0.0.23, the compiler does not work
Please click "Compile to HEX" while holding down the Ctrl key and post the messages from the compiler window. This provides verbose debugging info that will help us determine the problem.
Sorry - just noticed you said you updated to v9.0.0.23. This is the older original release of Flowcode v9. The latest release is v9.1.0.27. Please update to this version and try again.
jirikadlcak
I did an update, but unfortunately it didn't help. I'm sending a Compiler message.
The most important error is on this line:
Ended polling
but i don't know how to remove it, what's wrong with my configuration.
Jiri
The full list of Compiler message is here:
Title:
Description:
Generated by: Flowcode v9.1.0.27
Date: Monday, April 26, 2021 17:09:59
Users: 1
Licence key: MXYUWW
Using <JK test> user settings for compiler
Debug: PathName is C:\Program Files (x86)\Flowcode v9\data\DefaultData\FlowcodeV9\FCD\PIC16\batchfiles\pic16_C30_comp.bat
Debug: Params are "C:\Program Files (x86)\Flowcode\Compilers\pic16\\" "I2C_v4_1_pracovni_08042020" "C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021\" "33EP256MU806"
Debug: CurDir is C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021
Debug: LongPath is C:\WINDOWS\system32\cmd.exe
Debug: LaunchPath is /C ""C:\Program Files (x86)\Flowcode v9\data\DefaultData\FlowcodeV9\FCD\PIC16\batchfiles\pic16_C30_comp.bat" "C:\Program Files (x86)\Flowcode\Compilers\pic16\\" "I2C_v4_1_pracovni_08042020" "C:\Users\kadlcak\Documents\Documents\Documents\Projekty 2021\S-LOV\PDCHTL\TICs\Program\12042021\" "33EP256MU806""
Starting polling...
Ended polling
FINISHED
Thanks.
I notice you are using your own <JK test> setting within Compiler Settings. What happens if you use the default settings instead (e.g. "PICkit2 PKCMD External Power")? You need to go into the Compiler Settings screen and tick the appropriate "Default compiler..." tickbox.
If that also fails, then it could be a problem with either path size or the filename length. Some compiler toolchains have restrictions on these. Try renaming your file to something shorter and perhaps use a location for your project closer to the root of your C: drive.
Has thanked: 94 times
Been thanked: 288 times
Also, if Steve's suggestions regarding using the default setting etc., does not fix the issue,
could you check the toolchain path in the Locations tab of the Global Settings
when I test I get this
... -I"C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\" -std=gnu99 ...
I noticed in your log there is an extra backslash in the compiler path, which might be causing the issue
... -I"C:\Program Files (x86)\Flowcode\Compilers\pic16\\" -std=gnu99 ...
jirikadlcak
I apologize for the complications, I set the recommended compilation, I saved the file to the adirectory directly in root C: (C: \ FlowCode programs) and still the same. I am attaching three files. The first is a screenshot of the compiler and linker settings. The second is when compiling and linking the same program for BL032 (works normally). The third is for compilation and linking directly for 33EP256MU806 (generates an error).
What's next? Thanks a lot. Jiri
Target folder for BL032.docx
(14.41 KiB) Downloaded 616 times
General setting.docx
(244.52 KiB) Downloaded 804 times
33EP256MU806.docx
(13.46 KiB) Downloaded 646 times
In General Options, please go to the "locations" tab and ensure the location of the toolchain has only one "\" at the end of it and see if that helps.
jirikadlcak
Thank you very much, it helped. In "Global setting, I changed under " location" from
" C: \ Program Files (x86) \ Flowcode \ Compilers \ pic16 \ "
to
" C: \ Program Files (x86) \ Flowcode \ Compilers \ pic16 "
and the compiler works .
Thank you Jiri
