On a first build try, I’m getting the error message below. As you see it does not find the “F469Discovey.h” file. However, I do find this include file. I assume there is a path problem or something I need to setup or point to.
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ARM\batch\..\inc" -I"C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ARM\batch\..\boards" -O3 -fmessage-length=0 -fdata-sections -ffunction-sections -w -c "Flowcode1.c" -o "Flowcode1_STM32F469xx_8000000\Flowcode1.o"
Flowcode1.c:33:27: fatal error: F469Discovery.h: No such file or directory
compilation terminated.
Error(s) in build
Using STM32F469 Discovery kit, as you can see, and running V9 of Flowcode.
Any ideas for this newbie?
No such file or directory error message --on build
Cslices
- Has thanked: 94 times
- Been thanked: 288 times
Re: No such file or directory error message --on build
Thanks for letting us know.
Please rename the attached file from F469Disco.bat.txt to F469Disco.bat
and drop into the following directory (please note that ProgramData is usually hidden)
- F469Disco.bat.txt
- (6.78 KiB) Downloaded 337 times
