Network Interface dropdown menu error
ssttrragmail
Has thanked: 18 times
Been thanked: 2 times
Post by ssttrragmail »
In the "NetworkComms" component I´m trying to set the corresponding interface of my PC by the "Network Interface" dropdown menu.
It has worked once, and I got a right number and the PC´s IP. But after that, I´m getting just a half blank space rather then the expected interface numbers to make a choice. What could be wrong ? FC9 or Windows10 configuration ? Thank you.
Network Interface dropdown menu error.jpg (65.21 KiB) Viewed 3672 times
ssttrragmail
Re: Network Interface dropdown menu error
Just to show the issue by another perspective, I did the Wiki example Example Network Comms Web Server (below) in a new instance of FC9. Still got the half blank "Network Interface" field. So I can´t be able to visualize the PC´s interface numbers, and consequently determine the PC´s IP adress.
Please, any clue how overcome this situation ?
Network Interface dropdown menu error 2.jpg (93.92 KiB) Viewed 3648 times
ssttrragmail
If anybody had this issue, the clue is : just reinstall entire FC9 again, and you´ll get rid of that half blank field. That simple.
