Afternoon,
Is it possible to be able to select multiple items (including text blocks) either by the "Cross window method" or by pressing and holding "CTRL" and selecting items so that they can be moved. As a group ?
As the "Cross window method" doesn't select the text blocks.
Or can this be done by another method and i am selecting incorrectly ?
text block origins / grips are not where you think vs the component ones, and can be selected by cross window method
2D Dashboard Select Multiple items - { Solved }
steve001
- Has thanked: 81 times
- Been thanked: 30 times
- Has thanked: 795 times
- Been thanked: 858 times
Re: 2D Dashboard Select Multiple items - { Solved }
Hi, Steve.
If rubber band (left-click & swiping with mouse) selection is not working to well for you,
then you can hold Shift down & multiple select.
