UART Interrupt Clear Question.(Solved)
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Hi!
I have some question.
I'm using PIC18F47Q10. I want recive via UART Interrupt.
But interrupt is not clear.
Execute user macro through receive interrupt. And when the receive interrupt comes in once,
it operates as if the interrupt continues to occur.
If someone knows how to clear the interrupt, please help.
Thank you.
Serial_Test.fcfx
(28.27 KiB) Downloaded 455 times
Has thanked: 103 times
Been thanked: 302 times
Re: UART Interrupt Clear Question.
In the interrupt macro, you need to call ReceiveChar for the UART that caused the interrupt.
Doing this will clear the interrupt.
Best then to set a global flag, and then call the string send from the main loop.
Keep functionality in the interrupt routine to a minimum, sending a string from there is not advisable.
seokgi
Post by seokgi »
Thank you for your help.
All is clear
Thank you
