I would like this model added.
The only difference of this cheap china model that they propose as a replacement for the Nokia 5110 display with the model that uses ili9163C spi 160 x 128 pixels, are only the dimensions of 1.44 "and the pixels that are 128 x 128.with some tricks you can partially fool flowcode 9 using the same ili9163 by moving the text down .... You could do a flowcode subroutine converting pixel dimensions from the model to 160 x 128 to 128 x 128 ..... Boh , I do not know you see ..... Thanks Alessandro.
thanks.
solozerouno .
ILI9163C China model 1.44 " spi 128 x 128 display
solozerouno
- Has thanked: 2 times
- Been thanked: 2 times
- Has thanked: 615 times
- Been thanked: 814 times
Re: ILI9163C China model 1.44 " spi 128 x 128 display
Is it just that the display your using required a shift so 0,0 on the coords is not 0,0 on the display? We can potentially add new shift properties to allow you to set the amount of shift in the component. I have done this already for other displays.
solozerouno
Yes you should redefine the display to 128 x 128 1.44 ", I repeat from china this product is very popular because it costs almost a third less than the more famous 160 x 128 1.8" both with ILI9163C driver changes only the pixels and when you simulation on flc9 above is empty ....
Thanks Alessandro.
Thanks Alessandro.
