Serial Comunication (esp32, app developer)
Oscar_T
Has thanked: 37 times
Been thanked: 10 times
Post by Oscar_T »
Hello everybody
I have a question about serial communication (com port)
I am currently using esp32 devkit to build a small test station. The program is very simple and is based on sending and receiving data from the esp32.
The problem arises when I have to send and receive LONG or FLOAT data. If I send a single data (such as the reading of an adc) I have no problems, but if I want to send more then I get lost.
For example in the attached program I try to send 3 float values ​​consecutively from the esp32 card and these values ​​must be saved in the program. files are not saved or data does not arrive.
Another thing I noticed that when I send the data from the PC, in the console are sent doubles (only when I send the floats or number). This does not happen if I send a single byte
I would like to understand if it is a timing issue or the way I send and receive data is wrong.
Flowcode_example.fcfx
(12.14 KiB) Downloaded 373 times
APP_PC.fcsx
(14.01 KiB) Downloaded 427 times
Has thanked: 595 times
Been thanked: 785 times
Re: Serial Comunication (esp32, app developer)
You could solve this one of two ways.
1) After transmitting each float transmit a ',' character or something else none numeric ( '0' - '9' ) so the routine to receive the float has a delimiter to know when one value ends and the next begins. You might also need a delay after sending each comma to allow the conversion of the ASCII string back into a float format to avoid flooding the MCU UART receive buffer (not likely on the ESP hardware but very likely on something like a PIC/AVR).
2) Instead of using the SendFloat and ReceiveFloat functions you could use the SendBinaryFloat and ReceiveBinaryFloat as this has a fixed with of 4 bytes and so no delimiter character would be required. It won't be readable in the console / terminal emulator but it will be more efficient in terms of less bytes being transmitted and less numeric manipulation to get to and from the float variable.
Hope this helps ;)
Oscar_T
Post by Oscar_T »
I try to implement the recommendations and let you know!
Edit
With the first solution I was lucky and by inserting a character I can send floats in sequence.
Unfortunately not with the second solution.
In the next few days I will try to understand why it doesn't work
