quadrature rotary encoder
Sundwell
Post by Sundwell »
Hi Flowcode staff.
In Flowcode 9 the quadrature rotary encoder component is in the wrong component list.
It is located in Mechatronics, but should be located in Basic I / O
Henrik
Has thanked: 647 times
Been thanked: 856 times
Re: quadrature rotary encoder
Hello Henrik,
Please be aware that the licensing of component packs doesn't nessisarily correspond with the listing in the component toolbar. We do this where possible but in some cases it's simpler not to.
Sundwell
Post by Sundwell »
The problem is that I now no longer have the license for the encoder component.
If I go to your website to buy it, it is below the basic I / O that I have bought.
best regards Henrik
zoli2496
Been thanked: 2 times
Post by zoli2496 »
I bought the Basic IO module, I can't use the Quadrature Encoder in it. And he's on the list. Why can't I use it? Why is "QuadEnc" listed on the Basic IO website?
I'm looking for a solution, thank you.
Has thanked: 794 times
Been thanked: 858 times
Hi zoli2496.
Thank you for the spot.
The basic IO showing quadrature encoder is a mistake.
The first image showing quadrature encoder within Mechatronics is correct.
All the components within the first image will be correct as it is now auto-generated.
This issue will be looked into and corrected.
