MQTT
Alan_37
Has thanked: 57 times
Been thanked: 28 times
MQTT
Post by Alan_37 »
Good morning,
Is it possible to have the MQTT Address as a variable? so that we can set it when the code is running
Has thanked: 300 times
Been thanked: 465 times
Re: MQTT
If you are creating an App Developer program that is running on the PC, then you can use a simulation macro to alter any property value (Component.Property.SetValue). However, for an embedded program, the host address of the MQTT_Client component is currently hardcoded.
It might be possible to include a function to set this value in a future update of the component. I'll ask Ben or Leigh to comment...
Has thanked: 629 times
Been thanked: 836 times
Re: MQTT
Hi Alan,
I've now added in this functionality for you via a new property to enable it and a new macro to set the address.
I'll get it pushed to the update system shortly.
Alan_37
Re: MQTT
Post by Alan_37 »
Hi Ben / Steve
Thanks for your prompt reply and fix will update and test.
Thanks again
