https://www.matrixtsl.com/mmforums/view ... 94#p104194
After a lot of testing with various screen resolutions and text size, I have come to the conclusion that FC9 does not support 3840 x 1080 with 100% text size. if I increase text to 150% then it will be ok but then everything else will be too big so that way I can not have it.
Do you have time to make FC9 compatible with this resolution?
I have the same problem in FC7.
a problem with the text size in FC9 and FC7
- Been thanked: 2 times
Re: a problem with the text size in FC9 and FC7
i have the same issue, test a lot of combination without success...
- Has thanked: 204 times
- Been thanked: 349 times
Please give some some details (e.g. resolution of monitor(s), screenshots) and I will look into it.
The problem that arises is that the display seems correct but only in some aspects while in others (for example the overlapping program icons or the very large or very small text depending on the active window) the display appears wrong.
The problem is certainly reproducible if you use a PC with a UHD graphics card and try to display it on a 4K capable monitor with HDMI cable: any setting above 1920 x 1080 will cause problems. The phenomenon is reproducible, albeit in a less evident way, even on Microsoft Surface (yes I know it is certainly not suitable for use) and it was also for Flowcode 8.
Thanks - I will try to source a monitor and graphics card so I can reproduce the problem and try to fix it.
We've purchased a 4k monitor and I've posted an update of my experiences here:
https://www.matrixtsl.com/mmforums/view ... 94#p104494
Basically, it largely appears fine on my setup. I know this is not going to be of comfort for users having problems with their setup.
My conclusion is that with the right combination of Windows settings, Flowcode doesn't have a problem with 4k. Short of me sourcing the exact monitor and exact graphics card that is causing the problems with other users, I'm not sure what I can do.
