SSD1322 Graphic display
studentcompanion
Has thanked: 2 times
Post by studentcompanion »
Good day,
Has anyone been successful using the SSD1322 Graphic display controller (Newheaven 25664 or similar) with Flowcode v9?
I have a simple demo suing PIC16F18877 just to initialize and print a simple text but the display doesn't seem to work or initialize.
I have tried the SSD1322 buffered(serial) and Parallel with no results.
Here is my SSD1322 buffered project attached. Any hint will be appreciated.
Does Flowcode handle the PPS config automatically when one select the pins?
Newheaven.fcfx
(11.64 KiB) Downloaded 853 times
Free online Microcontroller Tutorials & Projects for beginners to advanced.
Website: https://www.studentcompanion.co.za/cate ... e-for-pic/
YouTube Tutorials: https://www.youtube.com/user/StudentCompanionSA
Has thanked: 647 times
Been thanked: 856 times
Re: SSD1322 Graphic display
Thanks for letting us know. I'll see if I can get my hands on a display and do some testing.
studentcompanion
Thanks for your time.
I'm really struggling to get my hands on one of these displays. The only thing I can find that comes close is one based on a SSD1326.
I can have a look through the code and see if I can spot anything but it's harder when you don't have the thing in front of you.
Do you have a link to the product your using and a datasheet for it so I can be sure of what I'm aiming for?
studentcompanion
Hi Ben,
Thanks again for your feedback.
These are the links to the documentations for the device I am using (Newhaven NHD 3.12 - 25664: https://www.newhavendisplay.com/nhd3122 ... -6092.html):
Datasheet: https://www.newhavendisplay.com/resourc ... SD1322.pdf
Sample code: https://www.newhavendisplay.com/resourc ... _25664.txt
Application Notes: https://www.newhavendisplay.com/app_notes/SSD1322.pdf
ics1
Post by ics1 »
hi sir myself was trying to interface the ssd1322 and iam not able to get lcd on and i used parallel mode of interface plz can you provide me the source code so that i will to interface and edit the code according to my requirement plz sir thanks in advance
