Butzer does not go out again
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
Small error in the simulation.
Start a new project, processor not important.
Choose an output.
Set only Butzer or nothing else and start the simulation and then end the simulation.
have fun :D :lol:
SpeedPic32
Has thanked: 311 times
Been thanked: 479 times
Re: Butzer does not go out again
Thanks, but I'm not sure I understand (and I don't know what "Butzer" is). Can you attach a program, list the exact steps and explain what the error is please?
SpeedPIC32
hello,
this is a typo on my part, sorry. :oops:
I mean buzzer.
I mean a debugging error.
If the debugging stops or aborts then it should really do that.
Actually you don't do it like I did, but you should change it I think.
Debugger off and all states that are only simulated on the computer should then also be off. In this particular case I had to close FC9 first.
Meanwhile I know how to do it.
You rewrite the software and debug it again.
See Programme Buzzer
have fun
SpeedPic32 :P
SpeedPIC32
Buzzer.fcfx
(6.76 KiB) Downloaded 642 times
Has thanked: 794 times
Been thanked: 853 times
Hi SpeedPic32,
I agree that the buzzer should go off when simulation has stopped.
There is a workaround.
There is an event simulation stop you can use to turn the buzzer off when the simulation has stopped.
To add the Event, you select the EV icon within Project explorer.
Expand Simulation, then double click Stop, double click Add New on the popup window, select OK on the next popup window, then select OK again.
A new function macro will be set. I just added BuzzerOff in that.
Buzzer.fcfx
(7.68 KiB) Downloaded 643 times
Thanks for the explanation, SpeedPic32. And thanks for the fix, Martin.
I'll ask Ben to see if it is worth having the stop simulation event trapped by the component itself.
Has thanked: 647 times
Been thanked: 856 times
Yes thanks for letting us know. I have now added a sim stop event to the component which should stop the buzzer from sounding.
I'll push out the new component to the update system later today.
SpeedPIC32
hello Team ,
unfortunately this is only a 4 according to school grades
The software has only two commands
1. buzzer on
2. 2sec Wait
The simmulation stops, ...good.
Now comes the new error.
When I start the same simulation for the second time, there is no sound.
I have to close the software, then it only works once again.
If I add BuzzerOff as a third time, the simulation runs well and again.
Greetings to the team
Even if I get on your nerves with this, FC9 is getting better.
SpeedPic32
Hi SpeedPic32
For now can you try something?
In file explorer address bar, paste this:
C:\ProgramData\MatrixTSL\FlowcodeV9\Components
Extract the component within the attached zip file and save it into the above hidden folder.
Just select ok to replace the current file.
If you got Flowcode loaded when file was placed the components directory, you must select the reload icon before compiling again.
Buzzer.zip
(3.67 KiB) Downloaded 640 times
SpeedPIC32
hi medelec35
it's ok now
Question: How can I thank someone in the forum?
Greeting SpeedPic32
