Kisen
- Has thanked: 2 times
- Been thanked: 1 time
Post
by Kisen »
I am trying to use the UART RX Interrupts.
When compiling i am getting errors.
v0.1.c
10: error: '__IPC6bits_t' has no member named 'U1RXIP'
v0.1.c
10: error: '__IPC6bits_t' has no member named 'U1RXIS'
v0.1.c
2: error: Vector number must be an integer between 0 and 255
The only way i can remove these errors is to delete the interrupt macro.
PIC32MX575F256L chip is being used.
For my project i will need to use 3 RX Interrupts on 3 different channels.
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
Post
by SpeedPIC32 »
have tested this with other MX chips, they make the same mistake
greetings SpeedPic32
PIc32MX775
- Has thanked: 647 times
- Been thanked: 856 times
Post
by BenR »
Many thanks for letting us know of the issue. I have now posted some updates which should hopefully solve the problems for you.
Kisen
Post
by Kisen »
Thanks Ben,
Tested and working as expected now.
