Warning during compiling - Strings
Kisen
Has thanked: 2 times
Post by Kisen »
I am getting the following warnings when compiling.
Can you guys tell me what the warnings are for, please.
v0.1.c:3890:2: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [enabled by default]
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\PIC32BIT_CAL_String.c:542:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
v0.1.c:3243:6: note: expected 'MX_CHAR *' but argument is of type 'volatile MX_CHAR *'
I have about 20 warnings like this just repeating with different variables.
My program appears to be working fine even with the warnings, but when working on a big program and you get these warnings at the start, it kinda makes you feel like you are building on sand.
Has thanked: 616 times
Been thanked: 814 times
Re: Warning during compiling - Strings
Yes the warnings are annoying. It's mainly because strings are expected to be of type signed char and Flowcode doesn't support signed chars. As you say there wont actually be an issue running on the MCU.
We are aware of the problem and have some ideas to try and reduce these warnings as you're right it's not ideal that they are generated.
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
Hi Ben,
Isn’t there a compiler switch to switch these warnings off?
