What app do folk use to view source file?
I have used Brackets and Code Writer... but neither of these can be called via the "View C Code" tabs in FC.
Code Writer is a Win10 integrated app, can't seem to locate a call parameter for this....
and Brackets can be called but only displays a "New" file (these care the call parameters: $(outdir)$(target).c
and (outdir) correctly points to my sources.
App to view source and assembler files?
TimN-MK
- Has thanked: 292 times
- Been thanked: 458 times
Re: App to view source and assembler files?
I personally use TextPad, and I'm not familiar with the other tools you mention.
It seems Code Writer has some restrictions that prevent it from working. I found this from a search asking how to open a file via the command line:
For Brackets, this might help: https://blog.founderatwork.com/using-br ... n-windows/I feel your frustration but it's not a restriction imposed by us. It's due to Microsoft putting all UWP apps like Code Writer in a security sandbox that prevents file access unless the user has previously opened a file via a dialog. It's really annoying for our kind of app but unfortunately is managed by the core Microsoft file APIs we call, so we are affected downstream by it.
